Reload this Page >
Funtana 90 Servos
Funtana 90 Servos
Old 02-12-2006, 10:15 AM
flipflop
Default Funtana 90 Servos
Would you guys be afraid to use the Hitec 5975HB Karbonite servos in the Funtana? I bought these a couple of years ago for my Wildhare Edge but have been afraid to use them after all the reports of the gears breaking started coming in.
Old 02-12-2006, 11:31 AM
STG
My Feedback: (26)
STG's Avatar
Default RE: Funtana 90 Servos
ORIGINAL: flipflop
Chris M., Ian W. and a lot of others are using the same gear-train on the UL Giles(bit bigger) and E.F. Yak without any problems. H.T. says they are good up to a 12 pound plane.
That being said, with 3D throws there is a lot of mechanical disadvantage over the servo gear-train. It does not take that big of a bump on the ground to cause problems--as you have seen by reports.
I would say if you can't use them in the F90 what can you use them in?
Old 02-12-2006, 08:10 PM
Shawnlh
My Feedback: (-1)
Shawnlh's Avatar
I use the 975's in my F90, flew all last year with them, and have had no problems at all. Lot's of torque, and too fast, had to dial in quite a bit of expo to slow them down.
Old 02-13-2006, 11:39 PM
dakster1a
STG- after your wisdom, I changed my 425's on the elevator and rudder to 625's. Thanks, you probably saved my plane. Anyway, I think the karbonite gears might list them as o.k. for a 12 pound plane, let's look at the size of the ailerons of the Funtana 90. They are doing twice the work on a 9 pound plane (because of their size) than the much smaller ailerons of a 12 pound pattern plane. Agree?
Old 02-14-2006, 01:11 PM
STG
My Feedback: (26)
STG's Avatar
The geartrain in the 635/6635HB and 69XX series servos are approximately 30% thicker so are stronger than the 475/5475HB servos. We recommend an 8 lb limit per servo per control surface with the 475 and 5475, but increase that to 12lbs with the 635/6635 and 69XX series servos. MikeMayberry
http://www.rcuniverse.com/forum/m_27...tm.htm#2726160 Mike Mayberry, Hitec RCD Rep http://www.hitecrcd.com
If you don't have 3D throws then the weight can go up.
Old 02-14-2006, 01:20 PM
STG
My Feedback: (26)
STG's Avatar
ORIGINAL: dakster1a
On a pattern plane you will most likely not have the wild 3D throws (18° max not 50° max) so the weight can go up.
I think the biggest danger with the non-metal gear train is bumping on the ground. The heavier the model the bigger the bump and the more throw set-up the higher mechanical disadvantage over the servo. Problem is you don't always know there is something wrong with your gear train until you are in the air.
Old 02-14-2006, 07:23 PM
flipflop
Thanks for the input guys, really appreciate it. I had already seen Hitecs recommendation of 12 lbs max, that won't be a problem with the Funtana. What's got me worried, I was planning on using a small gasser and tuned pipe, ala Dick Hanson and they also say don't use them with gassers I'm kinda stuck between a rock and a hard place with a leaky boat and a broken paddle. I did have a 475HB fail after 5 flights installed on an elevator half of an Ultra Spadstick, but to be fair to Hitec, I do remember bumping that elevator when I was putting the plane in the car that day (no crash, it flew just fine on one elevator)
Old 02-15-2006, 10:27 AM
STG
My Feedback: (26)
STG's Avatar
ORIGINAL: flipflop
I don't think they are talking about the 1.6 gasser -- That thing is as smoother than any 4 stroke of comparable power.
The more you have your throws cranked up (3D throws--mechanical disadvantage to servo) the more a little bump gets amplified.
