Indoor 3D , Texas Style
#76
Hi Doug
What do you plan on using for radio equipmet like for reciever and servos. Do you think HS-55 servos would have enough torque or speed. Or would you have to go for more power. And what kinda of reciever are you going to use.
#77
tribute
Just got an email from the guys at Powerflite. 20 production models of the tribute will be at Toledo, hopefully. Email me for details at [email protected]
#78
Re: Hey guys
Originally posted by stomper
Heres Davids(Planesncopters) Scratch built foam edge 540profile fuse gws 370motorw/d gearbox flies well.
Well done David.
Doug
Well done David.
Doug
#82
motor tribute
The tribute uses a Hacker B20 S26 motor with a 4:1 gear reduction. U can sign up for one at www.bktsi.com. Im getting one myself. And it is blue foam...I think. Jeffrey
#83
KcFlyboy Hi first off I want to thank stomper for posting my pics for me! On to your Q. Yes I built it out of the Bluefoam {called bluecore } from Lowes I used Carobon arrow shafts from Easton, {called Specter Carbon5.0/830 Very small and light too. the motor is a gws ips duel, 9.7-1 geared. then I used 11-8gws prop w/kocams li poly 1020ma. gws ips 100 spd controlw/three Hs 50 servos Every thing except aileron servo is set up pull -pull.
#86
I found them in my local archery shop you might try to contact an archery shop in your location. If you can't find them there let me know , I'm thinking about ordering directly from the manufacterer, possibly less cost / currently paying $4.00 ea. Kind pricy "huh "
#89
Motor attatchment
Hi Joe : when I built my edge I glued in a carbon arrow shaft to stiffin up the fuse. where the motor goes I left enough arrow shaft exposed to slide the motor on the end after you trim the foam away to clear the motor and fasten with a small screw. Note : that on the gws deul motor, you want one motor on each side of your profile fuse. the arrow shaft is glued in along the thrust line in the fuse. look closely at my pic and you'll se what i 'm talking about. Hope this helps. If you need more help PM me with an E-mail add. and i'll send you more infoand pics. David
#91
NH
So, did anyone see the Indoor 3D Bipe that George has? I saw it in the District VIII report in the back of the June Model Aviation. Looks like an Ultimate.
#92
KCFLYBoy: I scratch Designed my edge to have a 36" w/s and a 33" fuse all up weight is 9.s oz. It's a great flyer! I didn't make any plans but if you give me a pm, with an e-mail address i'll send you a draft of my templates. David
#94
AZ
You can contact George Directly [email protected] or I beleive they are available through Aero Models.
Bill
Bill
#97
Hi Folks,
When are the Tributes going to be available for purchase? Can't seem to find anybody who has them for sale.
Thanks in advance,
Steve
Thanks in advance,
Steve
#98
AZ
Yes, the Tribute is available, I just picked mine up on Monday (Aero-Model is 20 minutes from my house) It is a very quick building plane, if I hadn't chosen to airbrush it, I am sure I would have flown it already. If anyone is unsure of how to build the landing gear, ask me, it is somewhat unclear in the instruction manual. Also omit step 9, as it has already been done for you. Also be warned that this plane has no hardware, but it has a very good list of stuff to get. Enjoy your planes, -Dan
#99
Tribute not on their website
Hi Guys......
Tribute doesnt seem to be listed on the AERO-model website.....cant seem to find it and I think i can order it online either.........anyone any suggestions. I send a mail to hovertoys lets see what they reply with.
Skypro......
Please update once u are flying
Regards
Aziz
Skypro......
Regards
Aziz
