Satio 125
1 Post
Satio 125
Hello guys, I have a quick question for you, does the satio 125 engine come with a pump ? the reason why I am asking is because I am thinking to get this engine to replace my OS 91 surpass II with pump engine that I am using to power my u can do 3d 60 with the fuel tank located on the CG.
thanks in advance
thanks in advance
VA
RE: Satio 125
what you do is either buy a pump or run a cline regulator. Im running the cline reg on my saito on my showtime 4d with the tank on the CG or as close as i could.
1 Post
RE: Satio 125
Thanks a lot guys.
One more question tho, is this engine as reliable as OS? What are the pros and cons of it? Will it be a good move going with this engine from 91 OS Surpass II engine? And finally will removing the muffler from my OS and running the headers only help with its performance a bit (I don't mind about noise)
btw, I had my share searching for the questions I posted above, but I Just wanted more recent answers than the ones I got from searched posts.
Thanks again
Ahmed
Thanks again
Ahmed
VA
RE: Satio 125
I just love my Saitos... I have 3 saitos now in my planes and i wouldn't replace any of them. If you looking for which is better you are going to bring up a war.
