Showtime 50 anyone?
Old 11-16-2007, 08:52 AM
  #201
RodanAZ
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Showtime 50 anyone?
ORIGINAL: dougtx
I have a question in regards to which engine to use on the ST50. Out of the Saito 82, Saito 91, and Saito 100, it appears that more comments are made towards using the 91 as opposed to the 82, however, according to Horizon Hobby, the 91 weighs in at 19.6, while the 100 weighs in at 19.5, so why wouldn't you want to use the 100 if it has basically the same weight as the 91 which seems to provide good results on this airplane?
Go with the 100! No reason not to go with a bigger motor at the same weight. I've got a YS .91 in mine and the power to weight is... satisfying.
RodanAZ is offline
Old 11-16-2007, 08:48 PM
  #202
jeanyves0922
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: RodanAZ
ORIGINAL: dougtx
I agree 100% with Rodan. I fly mine with the Magnum 91, heavier than these and still had to add 2oz to the nose. The ST50 is worth it too.
jeanyves0922 is offline
Old 11-16-2007, 11:37 PM
  #203
dougtx
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What kind of fuel consumption should I expect from the Saito 100, and what size prop do you guys think would be best suited for the ST50 / Saito 100 combination.
dougtx is offline
Old 11-17-2007, 08:05 AM
  #204
rmazuera
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dougtx, are you flying on a paved runway or grass?
I fly on paved runway so I use 16x6 APC on my YS-91. Tried 17x4W. Great on the air but can't keep the plane stopped on the ground. The 16x4W overrevs the engine a lot. I saw 10500's.
I have heard other Saito 100 owners flying with 15x6's.
Good luck and keep us posted!
rmazuera is offline
Old 11-17-2007, 09:58 AM
  #205
cloudancer03
My Feedback: (22)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
glad I saw this thread..a few years back I had the funtana 40 and used a 70 4stroke flew ok but needed more power.I want the ST50 but lacking a satio 82 I figured I could install a OS 91FS just laying around and from the threads I read it seems a 91 resolves tail heavy issues and the extra power is very good. what servos are you guys using .?
cloudancer03 is offline
Old 11-17-2007, 07:39 PM
  #206
dougtx
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
rmazuera,
Our field is very short, manicured grass.
dougtx is offline
Old 11-17-2007, 08:00 PM
  #207
Ken6PPC
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: dougtx
I'd try a 15 x 6 first. If you aren't happy with that one, you could try a 16 x 4W.
I fly my ST50 with a Saito 82 and 15 x 4 Pro Zinger or a 15 X 4W APC. I have also used 14 x 6 and 13 x 8, but I like the larger diameter props for this plane.
Ken6PPC is offline
Old 11-19-2007, 12:23 PM
  #208
jeanyves0922
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: cloudancer03
I use Hitec HS-325 on all surfaces except for the rudder where I use HS-475 (but the 325 would have been enough for the rudder). Also, I use 6.0V battery pack; if you use 4.8V, you might want to consider HS-475 on all surfaces.
Jean-Yves
Old 11-19-2007, 12:59 PM
  #209
Kruzer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello all. Was wondering if anyone in here has flown both the Showtime .50 and the Venus .40. I would like a comparison of the two with pluses and minuses. My interest is more in pattern flying but this model looks versatile. This thread makes the plane look good and is pretty helpful. Thanks all!
Kruzer is offline
Old 11-19-2007, 01:46 PM
  #210
RodanAZ
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have not flown the Venus, but the Showtime is definitely more pattern than 3D. It tracks like an arrow, and is very stable.
RodanAZ is offline
Old 12-14-2007, 10:08 PM
  #211
rmazuera
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I will be trying a 15x7 3-blade Master Airscrew prop tomorrow. I'm using a YS-91AC. Has anybody tried this? I'm tired of replacing 16x6's due to damages to prop.
Can't let a nice 83ºF day go by without some fun. Sorry for everybody up north. Nasty weather.
rmazuera is offline
Old 12-14-2007, 11:14 PM
  #212
Al Lewis
Banned
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Ernie!!! How's it going buddy??? I bought my son one of these last year and it flew really well. He's sinced switched to the 50 and 100 Funtana X though and likes them even more. Couldn't tell ya about the Showtime as I never fly anyone else's planes, even if I pay for them. Hope you like it buddy!!! Get across that bridge this spring and fly with me!!! I got some new 30%s you can try out!!! BTW You missed our airshow this year. Here's the video I shot of Kyle tearing up the sky, as usual!!!
http://media.putfile.com/Kyle-Whoyshnis
Al Lewis is offline
Old 01-04-2008, 10:53 PM
  #213
Kruzer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Took mine out of the box to begin a proper examination of the kit today. Not very happy with the finish on this kit. The covering is pretty rough and the decking fit and finish is not up to standard, so is the grey paintwork on it. There is a number on the inside of the fuse "18" is that an inspector's number?
The SFG plugs are not consistent with the top of the wing. I will have to remove the strip of covering to fill and then sand them to make them level with the wing surface. There is also some balsa visible around the SFG openings on the wing as the edges are not properly covered.
I can understand now why the Saito .82 is the biggest engine recommended for the frame and I will comply. The idea of building for both electric or glow has produced something less than the solid airplane I like. These light "cross breeds" will not really stand up as well to glow power vibration and loads. I am almost finshed building a Sig Sundancer .50 and to compare the two airplanes it's like chalk and cheese. Sig makes a solid airplane, this is my second ARF from them and no complaints about the build here. I guess for electric power the Showtime would be great. A buddy at the field just maidened an Inspire 60 and it's built the same way, pretty thin build for a .60 size glow airplane. Flitons are not the cheapest planes either. He has landing gear problems already with an OS91... go figure. I intend to beef up the gear support area before this Showtime even sees the field and am definitely not going this way again. Glow is glow and electric is electric. The funny thing is I do not dislike the airplane, it's just not what I expected. I am going to have to look at it again for strengthening it a little here and there, even if it's only with medium CA.
Kruzer is offline
Old 01-05-2008, 09:26 AM
  #214
RodanAZ
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mine has about 2 gallons through it with a YS .91 and no problems at all...
Yes, it is built light, and I did some strengthening in the landing gear mount, firewall, and a couple other spots, but I would have done the same with any ARF.
The covering on mine was pretty wrinkled out of the box, but tightened up nicely.
This plane is a great flyer, but IMHO an .82 Saito would not be all that exciting on this plane, which will come in ~ 7lbs. Geez, I was thinking about a Saito .82 for my 4lb Mojo!
It's not perfect, but for the price, I think this is a pretty nice plane, and it's a lot of fun to fly!
RodanAZ is offline
Old 01-05-2008, 06:24 PM
  #215
Kruzer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks RodanAZ, very encouraging. I cleaned and sanded the rough spots on the decking for repainting. This is the first plane I have ever bought that's built so light and designed for both electric & glow. For some of us change is hard to handle
If the .82 bores me it should not be too much trouble to up it I suppose ... I would upgrade the engine mount anyway if I was putting a 1.00.
I bought a Venus .40 and the build is very different, a buddy asked me and I sold it to him before I built it and got this as a replacement. Two verrry different airplanes. The plan is to fly more pattern than 3D. I'll let you know how the covering smoothens out.
I agree the ST is a nice looking airplane....... and fun is imperative!
Fly a lot! [8D]
Kruzer is offline
Old 01-05-2008, 07:52 PM
  #216
RodanAZ
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If pattern is your goal, you'll like the Showtime. It's no 3D plane, but it tracks like an arrow.
RodanAZ is offline
Old 02-01-2008, 05:53 PM
  #217
seemefly_1
seemefly_1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello I’m thinking about picking up a Showtime 50 and have 4 DS821 and want to put those in this plane. What do you think? Also I have a DX7 and will an AR6200 (the full range six channel receiver) fly this plane or do I need the AR7000 (seven channel full range receiver). Lastly will a Saito 72 work or an 82 be better as I’m trying to save a little.
seemefly_1 is offline
Old 02-01-2008, 06:12 PM
  #218
jamesrxx951
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
seemefly 1
i have a dx7 and i love it the 6200 receiver will work but from what i can tell this plane needs 6 servo's and that's ok but you have to slave the elevator to the gear side of the receiver and it will work but the gear switch also still controls the servo to. i have called horizon to see if this can be programmed out but it doesn't seem to be able. so it will work but be carefull not to hit the gear switch in flight or just get the ar7000. and if you are flying 3d get the biggest 4 stroke you can afford the 82 or the 91 which seems to be the most popular. try used in the ads in this web site.
jamesrxx951 is offline
Old 02-01-2008, 06:45 PM
  #219
jdkxtreme
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have a showtime 50 I would like sell..
jdkxtreme is offline
Old 02-01-2008, 07:23 PM
  #220
seemefly_1
seemefly_1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
what about the servos
Old 02-01-2008, 08:58 PM
  #221
jamesrxx951
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
seemefly 1
im not sure i your question is for the showtime for sale or if the 821 servos will work in that plane. if it is the servos should work just fine i used them in a funtana 50 and they were great and i'm going to use them in my showtime 50 when it shows up on my door step.
Old 02-01-2008, 10:05 PM
  #222
seemefly_1
seemefly_1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
no its about the DS821 in this plane
Old 02-05-2008, 12:11 AM
  #223
eddyimac
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi!
I have two engines available for the showtime 50 : OS 70 SurpassII and Evolution 52NX. What is the best?
Any help please!
Eddy
Thanks!
eddyimac is offline
Old 02-05-2008, 09:04 AM
  #224
RodanAZ
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Both would probably fly it, but you're not going to have a lot of performance. Remember this is a 6-7lb airplane, and a 50 isn't going to haul it around with any authority. I wouldn't go smaller than a .75 two stroke or .90 four stroke if you want any performance out of it. Mine came in a 7lbs with a YS .91, and the performance is excellent.
RodanAZ is offline
Old 02-06-2008, 01:10 PM
  #225
brandon13221
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i have the showtime 90 and the stock engine mount is just fine i have a os 91 four stroke and it fits nicely and flys good
brandon13221 is offline
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
