The Tango 40 ARF from Hangar 9
Where in Pa are you? I have my second tango ready to go.Lost the first one late last summer due to the rx battery coming unplugged..This one balanced at 5 1/2...I am going to use an os 55 i have here. the last one had a worn out os 50 and was a blast..Before I put the windshield on it i cut some balsa and painted it white so you could not see in the fuse..I should fly this in the next few days if the weather holds up....
Ohh ok. I live up 23 from lancaster in elverson..I did join a field in lancaster but I fly mosley at my house..Good to hear all went well with the maiden..
I run the APC 13x4 Sport prop on mine and it's a blast. Takes off in about 6 feet. I take off across the runway and as one commentor said "the runway's not real long but it sure is wide"
I've been flying mine electric for about a year and a half and love this funny little plane!
Harry
I just did the first flight on my tango last weekend after I had it trimmed when I landed it I noticed one aileron is a little bit higher than the other one and I do not know if that is normal or not. I also have another question from any body that is using the ailerons as flaps for landing or take offs and howshould I use them toreduce the landings because we have a very short strip.
Regarding flaps, I set the throws for the factory Hi and Lo rates then set the flaps switch drop both ailerons 75% of the Lo rate travel. I needed to add 5% down elevator to compensate for the extra lift. Be careful when setting this up, if you're off a little either way it can make for funny handling.
Harrymc is right, the Tango really doesn't need flaps, but it's pretty impressive to see how effective they are. Keep the nose up and a touch of throttle and you can land on a dime. I cut my takeoff distance in half using flaps. The Tango can be a little squirrely on the ground, so I figure the sooner we're off, the better. I should note that my plane probably has about half the power of most other posters on this thread. Have fun with it, you have a pretty versatile with with some quirky characteristics, but most people in this thread really seem to enjoy it.
Hello Folks, great thread! <o></o>
I’m going to be spending a week at <st1lace w:st="on"><st1lacetype w:st="on">Lake</st1lacetype> <st1lacename w:st="on">Powell</st1lacename></st1lace> and I have always wanted to have a float plane to use down there. The blue/orange Tango will make for some great pictures with the red rock and blue water. I want a plane with a lot of control authority and some very good slow speed lift. <o></o>
<o></o>
I ordered the eBay .40-60 size fiberglass floats (Item #320383842198) and I have a never used PTS Evo .46 lying around. The floats are: 33 inches long, 17 inches from tip of float to step, 4 inches high at step3.75 inches wide, 15-1/2 inches wide stance (center to center of floats), total weight 1.5 pounds! They seem big for the Tango but I have no experience with float planes.<o></o>
<o></o>
I like the Tango because it offers a very thick wing for slow speed take offs and a short approach with flaperons. I might need to do some tight maneuvering if we end up docking the house boat in a box canyon! I won’t be doing any hovering or knife edge loops with that motor and floats but I still will want some excellent climb performance in case I get in trouble. I will keep it light using that Evo .46 but with the floats that Tango is going to end up at about 7 pounds. Should I be concerned with that small motor? I have had a PTS mustang for about three years now and she does fine with that same motor at about 7 pounds. The Mustang always takes off easily in super tall grass; I hope the Tango might be similar with those big floats at step. <o></o>
<o></o>
Any prop suggestions for climb out performance, 12x4? The mustang is really fast (65 MPH) with a 10x8, and fine with an 11x7. As an FYI I have had countless electrics but my gas planes have been PTS ‘Stang, F-22 with .52, Pulse 60, and H9 P-40 .60. <o></o>
<o></o>
What do you all think am I crazy or will this be a maneuverable float plane? Other thoughts or other ideas?<o></o>
<meta content="text/html; charset=utf-8" http-equiv="Content-Type"><meta content="Word.Document" name="ProgId"><meta content="Microsoft Word 11" name="Generator"><meta content="Microsoft Word 11" name="Originator"><link href="file:///C:\DOCUME~1\BBUTTE~1.NHS\LOCALS~1\Temp\msohtml1\01 \clip_filelist.xml" rel="File-List" /><o:smarttagtype name="PlaceName" namespaceuri="urn:schemas-microsoft-comffice:smarttags"></o:smarttagtype><o:smarttagtype name="PlaceType" namespaceuri="urn:schemas-microsoft-comffice:smarttags"></o:smarttagtype><o:smarttagtype name="place" namespaceuri="urn:schemas-microsoft-comffice:smarttags"></o:smarttagtype><xml><w:worddocument><w:view></w:view><w:browserlevel></w:browserlevel></w:worddocument></xml><xml><w:latentstyles deflockedstate="false" latentstylecount="156"></w:latentstyles></xml></meta></meta></meta></meta>Edit-go with a 12.25x3.75 apc prop for plenty of torque. I'm sure your not worried that much about speed. Besides, with the thick wing the Tango has I wouldn't wanna push my luck trying to set anew airspeed record with it.
I apologize for my cheapness but this project has gotta be dang cheap. I also get to fly "real" airplanes but as fun as it is flying the big ones, they also cost me $150 an hour.
Thank you for your suggestions.
Brady
Other then that the plane looks excellent, the whole fuse us laser/ply. I’m pretty sure I can get it to 6.5 pounds with the floats. I’ll try it with the Evo .46 with out floats and then I’ll probably add a thunder tiger .55 or magnum .55. Is there a really good reason why I should spend another $60 for an OS? A $150 2 cycle seems some what ridiculous, why the higher price?
The TT .55 will be just fine also
I don’t see a problem adding the extra pound for the floats; I’ll get some pics up and let you all know how it goes.
