View Poll Results: A poll
Voters: 23. You may not vote on this poll
Which smaller/cheeper gasser for IMAC and 3d
AR
Which airplane would you choose for a non expensive airplane that is good at IMAC and 3d and why
If selected other please explain!
RE: Which smaller/cheeper gasser for IMAC and 3d
I did not vote because I don't have the experience to give you a good recomendation. I have been looking at the Extra 260 for best looks and now trying to settle on a brand. Wild Hare has one and advertize an astonishing weight of just 8.5 lbs. I wish they built one for the Evolution 35gt I already have. The hanger 9 planes I have have not held up well lately. Firewalls comming apart at the glue joints and all but I imagine all of them will do that so I just reinforce all of them now.
ORIGINAL: rc-plane
Some one marked other, what plane do you like better?
My Feedback: (10)
I have the Aeroworks YAK 54 .90-1.20 QB with an OS 120AX that will fly IMAC and 3d just fine. I have just orderd the WH 25% Extra 260 which is about the same size plane and have plans on putting the Brillelli 26cc engine on the business end swinging a 17X6 prop. This is a good size plane if your looking to start out in gas because it keeps the cast down compared to a 50cc plane yet its still a pretty good size plane and for 3D it should have plenty of power for pull out since the little 26cc gasser is puttiing out 10,000 rpm running a 16X8 prop. I like this size plane for it's ease of transportation and low cost
Mr67Stang,
Brillelli make a [link=http://www.scottellingson.com/brillelli_engines_009.htm]36cc engine[/link] for $365.00 and that includes that EI and muffler.
Mr67Stang,
OH
i thought Brillelli was just a converted wacker engine. and i 2nd zippy i dont have a aeroworks plane yet but it's in the works
ORIGINAL: Zippi
Mr67Stang,
Mr67Stang,
My Feedback: (40)
I voted for the WH for a couple reasons..
Prices are similar
WH has a lot of wing area and comes in at a good weight = good 3D plane
The WH will 3D better (has larger surfaces)
The overall end cost difference is not that much and you will have a lot more plane for a little bit more money
Prices are similar
My Feedback: (32)
Between the two I would do the Wildhare. Much better airframe for the first time gas pilot. They will stand up to some abuse.
Ease of assembly goes to the Hangar 9 though. Wildahre planes go together well but there are some things that are not explained in the manuals that are assumed that a person has enough experience to get the job done where as Hangar 9 manuals are well done with loads of pics and detailed explanantions of just about every step.
Now what would really help out is what engine do you plan to go with or is that another choice you want/need to make?
Just another option but not a recomendation. I have a Cermark Pitts S2B so when I get to it I will have a better idea as to the quality.
http://www.cermark.net/Show.php?TID=79&PSN=1647
To be more specific, the Brillelli engines are based on Echo chainsaws and the B46 on the Poulan saw. Quite a bit of machining has been done to loose any "extras" that are not needed and to transform into a desirable EI rc engine. Just like the Zenoahs that were originally in Red Max and Green Machine saws.
AZ
My 50 cc DA pulls a 17 lb plane vertical with enough authority to do unlimited sequence in IMAC. It probably is pulling in excess of 25 lbs. of thrust.
In order to do as well a 26 cc engine would have to be in an airframe at 8-9 lbs all up weight. Not many can make the weight requirement. Most 26 cc engines are way to heavy to make this possible.
I met several guys in Texas who were flying 25 cc gassers in the Sig Four Star finished out at about 14 lbs. With about 13-14 lbs thrust they made good sport flyers and would handle IMAC to the basic level, marginal at the sporstman level.
A 15 lb Aeroworks 540 29 % with the DA 50 would go vertical like a rocket and is quite buildable. Arthur Cloutier
Just because an airplane is light and has big wing area does not automatically mean that it will 3D or IMAC well. Granted light weight and lots of wing area does not hurt, but there is a lot more to it than just that. The plane has to be built right.. It needs to have incidence settings and moments that allow the plane to fly neutrally at a CG that does not require a lot of trim to fly straight and level but still be a little tail heavy. That helps to minimize coupling. The wing needs to be in the right place. It needs to be engineered so that it is lightweight and strong. Not all lightweight planes will hold up, but I must admit that most of the more popular designs that I have flown are all pretty well designed.
If I were going to look for a CHEAPER 25% gasser for 3D the Wild Hare would be a good choice. A cheaper option might be the World Models Katana... Its not super light but its reasonable less expensive and it flies IMAC style flying VERY well. They are not all that light, but they do fly straight and true.
If I had to save the money I would be inclined to go a little smaller and get the Extreme FLight 74" Yak and a Brillelli 46. Its going to be the best combination for the money. Its a little smaller overall, but it is light, it has proportionally large wings and its extremely well built. There is nothing that flies better in the 25% class except maybe the 50CC Extreme Flight planes, the Quique planes and the CH Double Vision which is another good, but not cheap plane.
The 74" EF Yak presents like a 25% plane, its BIG and it flies great. That would be my choice and the Brillelli is a great running and very reasonably priced engine that offsets the cost of the Airframe.
Ive been researching the same thing and personally am getting the EF yak 88 with DA50. I was almost going to get the WH suk. WH seem to make some quality products.
