offset control horns
im used to using stadard style control horns on all my airplane, i ran into some really nice looking carbon fiber horns, but they are meant to be used offset how will that affect my throws since they will be offset?....... http://www.petemodel.com/cfhorns.html
also what size do you recommend for a 28% edge
My Feedback: (82)
RE: offset control horns
These are the very best linkage you can get.
As long as the hole is right above your hinge gap, you should be fine. You also need the proper HD ball link, so there is no play.
The absolute best ARFs use a similar system.
I have not seen that sight before..Thanks....I just bought fiber horns from Extreme Flight and they actual get glued into the surfaces...no screws needed. payed 20 bucks for the ones used in there 88" Yak.
