Reload this Page >
Magic Hand 73" yak build thread
Old 09-09-2008, 04:03 AM
  #126
maineflyer
My Feedback: (44)
maineflyer's Avatar
Default RE: Magic Hand 73" yak build thread
lfuller,
My yak is flying great. I am in the middle of building the EF yak that is the same size. the throttle servo is in the box and the tank is just in front of the wink tube. I have moved my CG back as mentioned above. I flew it at a demo in 15-20 mph winds the other day and it tracks very well and flew well. Landing however is an experience with the rear CG as the plane tends to ballon some with the slightest elevator imput. I really like it though and hope ot fly it again soon. I would try your battery back near the front of the tank for balance at around 6" initially. Let me know how you make out.
Jeff
Old 09-23-2008, 10:57 PM
  #127
kochj
I just saw a advertisement for there 89" yak.... Looked at there 73 inch yak and was very interested and here I am!!!
Confused on one thing though...............
FG models IS Magic hand??
The quality and size seems equal to that of the EF yak..??
220$ this spring! wow I would have jumped on that Had I known about it.....
I was too busy buying up all the 80cc Lanier ARF's that were baught out by GP and were half priced.....
Anyway,,, I picked up a cg yak 67" and have not been too happy with it.... due to it's wa... Just not engough to support what the EF yak 74" and the 73" can
handle....
still seems like a great buy....
Justin
Old 09-24-2008, 04:46 AM
  #128
maineflyer
My Feedback: (44)
maineflyer's Avatar
Justin,
I am building an EF Yak right now and there are things I like out each (EF and MagicHand) better. The Magic Hand has much better glass work. The EF has removable tail and a slightly thicker airfoil along with a CF wingtube and better hardware. I have flown the 73" a number of times and it flys well and lands like a dream with my set up. I am anxious to get the EF in the air to compair. I heard that TBM had a version 2 coming out with a slightly longer nose and CF with tube and gear. The tube is very heavy. If you try one I think you will like it.
Jeff
Old 09-27-2008, 07:51 PM
  #129
kochj
Sounds fantastic....
I am a huge fan of EF products.
I plan on picking up there soon to be released 2M pattern plane....(I know, it is a bit, outside what they have been making)
I have no doubt that it will be every good as there other products.....
I do like the size of these yaks though....
perfect for everyday, park flying..... Fo me anyway...
I understand about the main wing tube.... CF is a nice upgrade for any of these aircrafts with removable wings...
I wonder if the version 2, will cause a price increase????
either way, thanks for you imput...
Justin
Old 09-29-2008, 10:40 PM
  #130
mjamm
Are the ailerons, elevators and rudder pre-hinged? If yes, what type of hinges?
Old 09-30-2008, 09:03 AM
  #131
maineflyer
My Feedback: (44)
maineflyer's Avatar
Yes they are pre-hinged with CA hinges. I tested them and they are fine. I have done blenders and snaps and have had no issues. I do als seal all my hing lines with clear Ultra or Mono cote from underneath to avoid flutter and this also gives a little extra strength.
Jeff
Old 09-30-2008, 10:04 PM
  #132
MarkF
On my 30% there robart type hinges and the tail is removable as well.
Mark
Old 10-03-2008, 08:43 PM
  #133
Ken Cz
Ken Cz's Avatar
Hi guys,
What are you all doing for spinners / prop nuts on the MH 73" Yak?
Plastic or Alum. spinner? TruTurn custom cut for your prop or what?
I am thinking about the Dubro Alum Spinner shaped prop nut as it avialable in colors - much lower cost than a spinner too.
What are your thoughts on the best way to go for looks and for using an electric starter??
If spinner, what brand and diameter?
cheers,
Ken Cz-
Old 10-03-2008, 09:33 PM
  #134
mjamm
I am so close in ordering one of these... I went to the site today and it looks like there is a new color scheme MHT0001-7. Orange/Black instead of the Red/Black. Looks nice!
I also read that the wing tube is carbon fiber... Is this new? I thought they were aluminum?
Price: $329.00 USD
Key Features:
• Great aerodynamic designed for 3D and precision aerobatics
• Strong Light Weight Construction
• Professionally covered
• Large control surfaces double beveled for maximum throw
• Cowl with cowl ring.
• Complete hardware included
• Carbon Fibe wingtube
• Painted aluminum landing gear
• Removable wings
• Laser cut engine mounting templates and mounting place indicated
Old 10-04-2008, 04:24 AM
  #135
maineflyer
My Feedback: (44)
maineflyer's Avatar
Yes,
The CF wing tube is new. I talked to the guys at TBM a while back and they said that the Generation 2 planes would be upgraded with CF tubes and a little longer nose to hlep with balance. They were also talking about CF landing gear. I think you will be impressed with it when you get it. The plane flys very well. I replumbed mine when it came because the fuel dot was undersized and TBM said they were fixing that also. Good luck and throw some photos up when you get it.
Jeff
Old 10-04-2008, 04:43 PM
  #136
Ken Cz
Ken Cz's Avatar
I have looked all over the TBM site and cannot find the new version of the MH 73" Yak in the new colors and with the CF wing tube I must be losing it - let me know how to find this info please.
Ken
Old 10-06-2008, 10:52 AM
  #137
mjamm
Ken, Sorry about that. The color scheme I seen was on the MagicHand-RC.com site, and not TBM.
Old 10-08-2008, 08:09 PM
  #138
Jetdesign
My Feedback: (8)
Jetdesign's Avatar
I"m tossed between this plane and the QQ 73" Yak, but this build thread is getting me exicted!
Can anyone report on weight issues with gas engines? I'm thinking of an RCGF 45cc at 55oz and 4.3hp.
Old 10-24-2008, 01:14 PM
  #139
f_shawn68
f_shawn68's Avatar
Just ran across this thread and I must say.....I GOTTA HAVE ONE...... I do have a few questions though. How large of a gasser could you put in one without balance issues or tearing the firewall off? What would be a good gasser to use? It would be my first gasser. Im tired of wiping oil off of my glow engines. I also fly at 4500 ASL. Everything I own right now has the next size larger from max recomendation in it to get the performance. I would also like to put a smoke system in it if there is room. Im not looking to do extreme 3D stuff with it, but some real good aerobatics and pattern type stuff peaks my intrest.
Any input would be appreciated. Thanks
Old 10-27-2008, 09:04 AM
  #140
maineflyer
My Feedback: (44)
maineflyer's Avatar
I would say anything that will give you 10lbs of thrust or more would be ok 30-4-cc. Balance wise the 1.60 balanced perfect and gives unlimited verticle. It is a well built plane
Old 10-27-2008, 10:19 PM
  #141
kochj
ORIGINAL: gaRCfield
I would go for the QQ yak 73"........No doubt due to winter sale going on now!!!
QQ yak 73" is 339.95$.... and that colour scheme is fantastic!!!
Same price, I am partial to qq planes, as I have always loved the qq brio shcemes... Not due to the name, but I love the colours.....
Unfortionatly, he has pulled it off his bigger planes and went to give his buddies props for their involvment with his new TI Python 150cc (Kimbal ent.)
The Scheme is the seller for me.... I would not buy one of his 85cc and up planes due to the change. Only his python still has it...
Magic hand looks fantastic, If it had a color shceme better than the Brio, I would buy that one!... All in the eyes of the beholder, I guess??
Old 11-04-2008, 05:25 PM
  #142
boosted180
My Feedback: (8)
anyone running a gasser on this plane? i was considering my brillelli 46cc on it, but may be too much engine for this plane. for anyone else who's running gas: what engine and what's your weight ending up to be?
didnt extreme flight use to have their 74" yak combo with a brillelli 46?
Old 03-13-2009, 09:06 AM
  #143
kochj
yep
Old 04-24-2009, 05:18 PM
  #144
samtech
samtech's Avatar
Anybody have the landing gear diminsions? Would aeroworks 1.20 yak carbon gear fit?
Old 04-24-2009, 08:53 PM
  #145
Ken Cz
Ken Cz's Avatar
TBM offers various sizes of CF gear although I am not sure if they have a direct replacement for the MH Yak 73".
A call to TBM might be helpful.
KC
Old 10-04-2009, 09:07 AM
  #146
AeroFinn
Hi Maineflyer and others!
This thread is just so interesting! How would you compare the Magic Hand Yak 54 73" and the EF Yak 54 74" which one suits better for IMAC practising? Or are both only for 3d?
I am planning to use a Laser 240-v glow. It weights about 44oz w/ mufflers and turns a 18*8 8400 rpm or 20*6 9000rpm
I guess the qq YAk 54 73" could be worth a closer look but since qq is out of the business I dunno..
Any ideas? thanks
Old 10-04-2009, 09:25 AM
  #147
maineflyer
My Feedback: (44)
maineflyer's Avatar
AeroFinn, I still have both, the EF and the magichand. I flew the EF yesterday and it flies like a dream. both inverted and upright with no stick input. You can independently adjust the stab halves. I liked the Magichand and it flies ok but their is no comparison to the EF. The EF has less coupling in knife edge and much stronger gear. Hope this helps. Either would be ok for IMAC practicing but the EF would be easier to tune
Jeff
Old 10-08-2009, 10:01 AM
  #148
kochj
EF doesn't make the 74" right now....
you will have to wait for the 74" extra...
Old 10-08-2009, 11:28 AM
  #149
rsrogers
My Feedback: (10)
rsrogers's Avatar
EX is coming out with a 78" Extra which should be here around Christmas. There are 2 versions & one of them is designed purposely for electric. I believe there will be a 78" Yak configured the same way as well.
I agree there are no comparison to the E.F. products!!!!
Old 10-09-2009, 06:46 AM
  #150
AeroFinn
Hi Maineflyer,
Thanks for your help. I guess I have to have a close look on what's going on with EF if they come out with a revised Yak etc.
regards artto
P.S. isn't it weird there isn't many Sukhois of this size on the market. The Sukhoi would a nice alternative, too.
