Saito 100 with 30% Nitro
Hi Guys
I need some advice, I run a Saito 100 in my Fliton Extra 330 Freestyle.
I use an APC 15X6 on 15% with a Saito plug and am getting 9400 rpm.
I know it sounds greedy but I’d like to see if I can get a bit more power.
How much of an increase in RPM do you think I could get if I switch to 30%?
My thoughts are that if I can get another 3 or 400 RPM I could use a bigger prop, maybe a 16X4W. I know that will drop the RPM again but hopefully no lower than 9300 or 9400 I started with.
Also is it worthwhile changing to an OS F type plug?
Someone did suggest I may get a problem with pre ignition on 30% and I should use a cooler plug, any views on this would be appreciated.
Many thanks
Don
Many thanks
Don
RE: Saito 100 with 30% Nitro
ORIGINAL: Falcon32
Hi Guys
Many thanks
Don
Hi Guys
Many thanks
Don
The other birds run a 14x6 to 14x8 @ around 10.8k on 30%. Flawless. All standard Saito plugs.
Hey Patrick
Good luck with the maiden, you'll love the extra, and thanks for the info, what do you think about the 16X4W prop?
Don
Don
ORIGINAL: Falcon32
Hey Patrick
Don
Hey Patrick
Don
Anyway its in one piece. I just did not mount the tank well enough and it came out in flight through the magnetically secured hatch. Dead sticked and pancaked the aluminum gear. No balsa damage thankfully. The thing was really pitchy on the elevator at low rate. Elevator travel I guess at 1.5"? Fealt really tail heavy too (before I jettisoned the tank). Funny...I CG'd it 125mm which is the going measurement according to RCU trollers. This is my first non-foamy acro plane so I'm not sure what to expect from a 60 size 330. Are you running a perry pump on yours? Sorry to change topic.
Hi Patrick
Glad to hear it’s all in one piece.
I’ve got a 15X4W that I’m going to try this week end.
Hopefully I’ll get about the same 9800 you did with the 30%.
I lost my hatch (held on with magnets) on the first snap!
Luckily I used some cable ties to hold the tank in.
I thought of bigger magnets, too much weight, so I just use some sticky tape.
I think most guys have used carbon U/C it’s heavier but much stronger and a little taller.
I think 1inch is probably enough for low rate on the elevator, and I like about 30% expo.
Your CG should be OK at 125mm I think mine is at about 130mm and its hands off inverted.
I’ve got the Saito inverted and a 12oz Dubro tank back to the wing tube, and use a Cline regulator, no fuel issues!
Hope you get yours back in the air soon.
Don
Don
FL
I have a Saito 100 and 125 and 30% is all that I use. Trust me, there is a big difference. I'm using a 15x4 on the 100 and a 16x4 on the 125. Only issue is the extra oil mess.
MI
closing the plant :::::: thats ok im almost done w/my gasser .. i've never tried the 30%or even 20% in my satio100.. although aftr reading this stuff i might ...it"s always ran good on 15 ?? w/ a 15x4... tachs upper 9's
ORIGINAL: Falcon32
Hi Patrick
Don
Hi Patrick
Don
Anyway back to topic, 20% is minimum nitro for me. And 30% it really sings. Really, at my local shops its only $3 more than the 15% at $21 to $23 gallon.
Thanks guys for the info on the props and fuel.
I'm going to try the 15X4W this weekend and see how it goes.
The APC props are like $30 here in the UK, so if I don't really need it I can put that money towards my next plane [8D]
Patrick It's no wonder you found it pitchy with 11/2 inches and no expo on the elevators
Don
Don
