Inspire 60 and saito 91
Location: SantiagoReg Metropolitana, Providencia, CHILE
i have an Inspire 60 and I will mount a saito 91 in front; the plane is designed arround a ys 63, so the tank is almost in the CG, Can I have some problems putting the tank there (in the CG) for my saito?? I know there are many people flying with saitos 82, where did you put the tank?
NE
RE: Inspire 60 and saito 91
Daniel,
Of course you'll ned to make adjustments for CofG.
But, the main thing to keep in mind is the height of the tank and the spraybar.
I used a Saito 91 in my Swallow, with the tank located at CofG. The main problem was, this placed the tank awfully high.
I ended up mounting my engine sideways, to get the spraybar close to the height of the tank.
Good luck, HTH,
EJ
Good luck, HTH,
EJ
