GP .60 Reactor Bibe
RE: GP .60 Reactor Bibe
ORIGINAL: fanoffive0
It looks great. Can't wait for the video. I also have one that is almost done. What exponential setting are you using?
Thanks...
Thanks...
One thing that takes a bit to get use to is landing. It is very easy but happens much quicker than you might expect. The airframe bleeds off speed really quick so you can come in hauling and with just a little slip it sits right down. Also the ground handling is awesome. Rough grass with the wheel pants on is no problem at all. The .91 pulls it very good. I test flew on a 97 degree 78% humidity day and it was decent. Yesterday was 70 Degrees and yes there was a notable power increase. If you live where it gets really hot and high density altitude is a problem more ponys will be needed. The new OS 1.10 four stroke seems like a great fit.
Has anyone tried one of those engines?
Jason
AE, GERMANY
ORIGINAL: Jason 3-Danhakl
......One thing that takes a bit to get use to is landing. It is very easy but happens much quicker than you might expect. The airframe bleeds off speed really quick so you can come in hauling and with just a little slip it sits right down......
Plane looks great! I found this part of your post to be interesting. I have the Reactor .46 with Saito .82 power and it does the same exact thing. I love starting an approach to high and fast, then pulling power and adding some up elevator to maintain some wing in the wind. It will make one of the prettiest steep approaches of any plane I have flown. Normal appraoches are best flown with a couple clicks up on the throttle. Mine will almost land itself! It is cool to see the good traits of the Reactor translate so well to different airframes!
#32
TX
Built mine last week and have about eight flights so far. I agree the roll rate it super-charged (about four rolls per second on high rate). There is a huge range for the recommended CG. Right now, I am in the middle of the range and the plane handles much better than my original full forward range. I will continue to shift the CG aft until I no longer care for the flight characteristics.
The engine is an OS .75 AX. It has great vertical and pulls out of a hoover easily. I still have a few more flights before I lean the engine for full power but for now I'm extremely happy with this engine for this plane.
The other Reactor in the picture with two is a friends who mounted a Zenoa G20 with a 17 inch prop. It flys a little heavier but has impressive speed and vertical climb-out.
#34
Well I did a flying video for Great Planes and they have it posted now at this link:
http://www.youtube.com/watch?v=Nf7Fb...e=channel_page
Note the Prop listed is incorrect. It is an APC 15x6 not a 15x16! Man that would haul if the engine didn't over heat taxing out! Anyway this is my personal model that was featured in this thread. I am really enjoying the model and hope this info helps everyone see some of the models potential. Please let me know your thoughts. That old .91 is pulling strong! One other thing to note is the wind was gusting to 15 during the video shoot.
Jason
Jason
#37
NY
Very nice flying Jason. Something about that bird reminds me of the old Top Flite Hot Kanary I have hanging in the rafters.
I've got way too many projects this summer, but now you have me wondering if those 48" wings will fit assembled in my car!
Great job. [sm=thumbup.gif]
#38
My Feedback: (7)
MO
Nice flight Jason. I'm sure gonna miss seeing you fly the u-can-do with the heli motor on it though. It sure doesn' look like it suffers in the vertical.
I'm gonna have to wait awhile to try one though. I picked up a 500 size helicopter and blew my rat-hole fund.[&o]
#39
ORIGINAL: 150flyer
Jason, how far back is your CG in that video? Are you at the full recommended aft?
150flyer
150flyer
Jason
#40
ORIGINAL: wind junkie
I've got way too many projects this summer, but now you have me wondering if those 48'' wings will fit assembled in my car!
I am able to put the Reactor Bibe in the cab of a Quad cab F-150 assembled. Once the airplane is in a standard size field box and TX case has plenty of room with it. The fuse length is where you might have trouble with the airplane assembled.
#41
ORIGINAL: gr8taz nitro
Be sure and buy plenty of thread locker! The .91 has good vertical but nothing like the hot rod U-Can-Do with Hyper .50. That airplane died at a night fly doing blenders! I still have all the servos and engine. You never know I might order another one. You know for stress relief!
Are you going to the Tulsa Heatwave? I will be there sweating it out.
Jason
#42
NY
#43
My Feedback: (7)
MO
Roy,
Jason
Roy,
Jason
The bipe does look good in the air though. I do have a saito 100 that could use a good home also. I'll have to take a closer look. Maybe I can get traded out and make it up Saturday.
#47
ORIGINAL: jpjamie
Jason:
Could you give us all some details as how you (plugged in etc.) wired the aileron servos?
Jason:
I turned on the Flaperon function and then used a Y on the top and bottom wing. So the bottom two servos are Y'd into the Aileron channel. The top two servos are Y'd into the Flap Channel. As I'm sure you know powering more than two servos from the same channel is not a good idea. The connectors can't safely handle the current. So doing it this way gets the load divided across two connectors.
Just make sure you get the linkage mechanically correct and centered with the wing tip and you will have no problems. I already mentioned this but you don't need much aileron throw at all. Also the Rudder is stupid effective so max throw on Rud is not needed either. I have no idea what the throw measurments are. I have been fine tuning to my liking in the air. Hope this helps you.
Jason
#48
MN
Not a problem. I am using a Futaba 7c radio which is somewhat limited in mixing functions for a 4 servo wing and dual elevator servo airplane.
Jason
ORIGINAL: jpjamie
Jason:
Jason:
Jason
The suggestion was aslo made I should run each aileron servo from a separate channel because of the current issue. If I can get my JR 9303 to mix this all up I may try it but I feel (and as your flight history demonstrates) using Y's will work just fine and way simpler! The instructions also mention using a voltage regulator and lithium-ion battery for power and voltage regulation. Would I need this or could I get by with a large capacity nicad?
One last thought. I have a U-Can-Do with a OS .91 installed. Wondering if I can just unbolt the mount and bolt it on the firewall on this bipe!? I doubt it, because of the firewall to spinner clearance issue, but you never know!
#49
ORIGINAL: jpjamie
Thanks Jason...perfect!
Jason
ORIGINAL: jpjamie
Jason:
Jason:
Jason
I would mount the engine exactly like the manual states. The CG will be much easier to hit that way.
Jason
#50
MN
If you are going to use a non Lithium battery I would go with the newer 2/3 C 1600 mha 6 volt nimh's. Hydrimax has one that really works good. About the same weight as a 2100 Lipo with Reg.
Jason
ORIGINAL: jpjamie
Jason
ORIGINAL: jpjamie
Jason:
Jason:
Jason
Jason
Just checked the instructions for the firewall to spinner distance and it is 5 5/8" from the firewall to spinner. Checked my U-Can-Do and the same distance is 5 6/8", so I'm just off by 1/8" inch! Will have to "weight" and see how the CG works out and check the spinner fit. Of course the engine mount to firewall (bolt pattern) may be entirely different....duh! Just trying to save time and work.
