GP .60 Reactor Bibe
Reply
Old 12-04-2010, 09:00 PM
  #201
ameyam
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: GP .60 Reactor Bibe
I have a 120AX as well but I think that will be too large. Otherwise I have a 75AX. Wasnt this airplane supposed to be 60 size?
Ameyam
ameyam is offline
Old 12-05-2010, 09:32 AM
  #202
luckyflyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Steinywi, how does your dle20 pull your reactor out from a hover?
luckyflyer is offline
Old 12-05-2010, 10:18 AM
  #203
steinywi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
like a rocket! it goes up and up and up! Little less than 8 pound plane with 14 pounds of thrust will be a great flyer, I just need some snow and it will be flying again! Seems like the Frozen Tundra is hard and very bumpy!
steinywi is offline
Old 12-05-2010, 10:22 AM
  #204
luckyflyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Cool, my ys 91ac is turning out to be a turd so I'm seriously considering the dle. Are you running just 1 battery pack for rx and ignition? Also did you need to put a hole in the firewall for the carb?
Old 12-05-2010, 11:47 AM
  #205
steinywi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The carb sits over the old fuel tank hole, I moved the tank back and put ign box behind firewall. No I'm still on 72mhz so 2 batts is the way to go! 2 1500's = 4 flights before charge.
steinywi is offline
Old 01-12-2011, 06:46 PM
  #206
kochj
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I thought the 1.20 sized engines would be too much as well, but if you compare another plane (sebart Misswind 50e)
The pattern guys are running 19inch PROPS on that plane!....They are electric but still....
This plane needs 1.25 4-stroke, or 2-stroke to have great aerobatic power....
Use servos that are good fro a 1.20 sized plane and use beefier control rods, arms and hardware...
The hardware is good for .46 size plans....
This is just what I would do....so do what you like....
I do wish this plane was abit bigger though....I would have purchased on already..
kochj is offline
Old 01-22-2011, 09:55 AM
  #207
livefast_livefun
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just received my new reactor bipe 61 and very pleased with the looks of the kit. Only one thing I found, they say you can use standard size servos in the rear for the elevator as well as rudder. So I cut the openings out only to find the standard one bottom out on the opposite side of the fuselage. My only way of thinking of resolving this is to build up a plate between the servo and fuselage, is this what ppl are doing? Thanks for any help
livefast_livefun is offline
Old 01-22-2011, 10:47 AM
  #208
rhd-RCU
rhd-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes
rhd-RCU is offline
Old 01-22-2011, 11:10 AM
  #209
livefast_livefun
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
k thanks thats what i will be doing. so looking forward to this spring to try this awsome looking plane out!!
Old 01-23-2011, 09:15 PM
  #210
wyo69cowboy
wyo69cowboy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I used Hitec 225's for the elevators and a standard size for the rudder; had to use a 1/8" plywood spacer for the standard servo so it wouldn't "bottom out" like you said...
wyo69cowboy is offline
Old 02-01-2012, 09:32 AM
  #211
ameyam
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This forum has been quiet for some time. I have already got a few replies on this but I am putting the discussion open to everyone- I am considering putting a DLE20 on the Reactor Bipe. I have already strengthened thje fuse section between the wings and am going to do the same for the LG section and block. I am open to other ideas and suggestions
Ameyam
ameyam is offline
Old 02-01-2012, 09:55 AM
  #212
rhd-RCU
rhd-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have an RCGF 20 on mine. All I did was stregthen the firewall area.
rhd-RCU is offline
Old 02-27-2012, 09:42 AM
  #213
kochj
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi guys....
I have finally got my reactor up and running (building that is)
I have the servos installed (I hate this part of the build)
Landing gear minum pants,the wings and elevators ....
All that is left to due is the motor, throttle servo. place electronics and battery...
I used all the the stock hardware ( I hope this will not bite me) but I didn't have
anything in this size to use, and I didn't want to spend 15-20$ on hardware....
The only thing noted was that my elevators don't want to match up there movements....
I had Hitech sevos in the tail, and these are shorter than the others...Futaba, MKS or others...so the only
servo hole that I had to add wood to lift it up was the MKS TI Rudder servo....
I can't tell if it is just me, or if something is warped, or perhaps I have the elevator not LEVEL....AHHHHHHHHHHHHHHHHHHHHHHHHHHHHGGGGGGGGGGGG G
I have been throwing around the engine choices as well....Gas/Glow....
I Think I may try to use this plane as a pattern setup, as the elevators and rudder, prevents huge 3D throws...
kochj is offline
Old 02-27-2012, 10:57 AM
  #214
steinywi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
DLE-20 and it is a 3D monster!
steinywi is offline
Old 02-27-2012, 05:26 PM
  #215
kochj
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I think I will stay with the Saito 125 for two reasons. Sound and down low grunt....this also keeps the speeds down and steady. The stock engine.mount doesn't seem up to challenge for a doe20cc.
kochj is offline
Old 02-27-2012, 07:24 PM
  #216
livefast_livefun
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hey does anybody have pics of the dle 20 mounted in the reactor? what engine mount are you guys using? thanks for your help.
Old 02-27-2012, 09:40 PM
  #217
kochj
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: livefast_livefun
There are picts on the previous page but as usuall...RCuni...is all messed up and doesn't show the pictures...
What a letdown....
RCuniverse is a mess .
kochj is offline
Old 02-28-2012, 06:58 AM
  #218
livefast_livefun
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well kinda crappy they show the pics. i have bought a dle 20 and would love to see a few pics of what ppl are doing with the firewall carb clearence. as well as what mount they are using to keep vibration down. could someone email me some pics? thanks livefast_livefun@hotmail.com
Old 02-28-2012, 07:04 AM
  #219
livefast_livefun
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I ment crappy they don`t show the pics
Old 02-28-2012, 08:22 AM
  #220
steinywi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
All I have for Now
I did modify the the mount I was using for my Saito 91.
steinywi is offline
Old 02-29-2012, 09:52 AM
  #221
kochj
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
does the muffler clear the cowl or do you have to cut a hole the size of the entire muffler?....
kochj is offline
Old 02-29-2012, 12:46 PM
  #222
wyo69cowboy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: kochj
Curious about that too; bet you're right though...[] Maybe one of the Pitts mufflers for the 20 might fit with little or no cutting on the side of the cowl. I love my bipe on 6S electric; just wish I could get a little longer than 7 minute flights. It's too much fun to have to land some times[8D]
Old 02-29-2012, 02:09 PM
  #223
kochj
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I really like the ease of gasoline, but the fit is quite tight furthermore, stock mufler really isn't a muffler, it is more of a muffled strait pipe. I would have to weld up a large volume mucked that could possibly fit on the battery compartment. Otherwise it would be too laud to run in populated areas...7
kochj is offline
Old 02-29-2012, 05:25 PM
  #224
steinywi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I know everybody is different, but I don’t mind the cowl cut. This plane is such a blast to fly. I have been out in 30 mph winds and I have giggled while I flew it. I’m not real worried about the looks of it but the performance is where it is at. This is a 7.5 pound plane with 14 pounds of thrust. It floats when I want it rolls so fast I have the ailerons back at 50% for normal flying. It will 3d as good as any bipe! This is my travel, windy, just want to have fun plane. I always land with a smile and others just shake their head!! The Saito 91 was fun but this is so much fun it should be illegal.
Steiny
You can’t see the cowl in the air.
steinywi is offline
Old 02-29-2012, 08:14 PM
  #225
livefast_livefun
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i found a header system that i think will clear the cowl. i em planning on making a setup very simler to this link http://ep.yimg.com/ca/I/yhst-1288974...3_2195_4692699 where i fly noise is not an issue. what are you guys doing to streathen the firewall...if anything? cant wait till spring to try this engine plane combo out! i em thinking of trying a smoker on this plane as well anyone done it with a dle20?
Reply
Display Modes
