Balancing AW 35CC Extra 260
VT
I will be mounting a DLE55 on a AW 35cc Extra 260.
Looking for radio gear locations to achieve the closest balance.
1) Location of the throttle servo?
2) Pull-Pull or rear mounted servo for rudder?
3) I will be using a 2700mah 6v nimh for servos and a 2300mah 4.8v for ignition. Best location for batteries?
This would help me out alot.
I know some of you have used DA50'S and DLE55'S on this plane. Looking forward to yopur suggestions here.
Thanks!
Thanks!
My Feedback: (57)
IN
RE: Balancing AW 35CC Extra 260
How do you know the tail would weigh the same as someone else's bird?
You cant go by what others have done except for a really course guess.
Mount the engine, put the gear in it while it's on a balance cradle. It's the only way to get it right.
