RE: U-Can-Do 3d 46?
Well I finally got my used 46 UCD in the air this morning:))) I
went to the field with both my 4*60 and UCD, which I made fit in my car. Was just going to tune the UCD's YS 63(older) and fly the 4*.. Anyway I got the YS running good.. And I said what the H_ll lets go for it..... She flew good!!! needed a couple clicks ail. and elev.. and she was ready to go.... I got 5 flights before the rain showed up...( I think my 4* is pissed at me) She hovers very easy, have to mix for the K.E. but was able to complete a circuit as is... inverted flight just took puching the sticks every now and then.. And she landed like a baby... Pull out from a hover was weak... I'm going to check the lifter gap, and may get more power yet.. But over all I like it!!! Not to sure on the long tail moment tho.. But she will let me "train more" for my next plane.... F-90 or EF Yak.... I did get a few comments fron the fellow club members.... they told me, Ron you know on a maiden flight, You need to learn the plane, before you doing the stuff you were doing....:-))))) |
RE: U-Can-Do 3d 46?
Raideron, They do seem to be good for training. I don't have a whole lot of time with mine but very impressed with what I've seen so far. It is soooo... fun to fly. And it's very stable in the air. I noticed that inverted flight is easier than with my Ultra stick. I haven't seen any bad habits. Looking forward to learning some 3D with it.
RE: U-Can-Do 3d 46?
Hey CeeGee.. They are fun to fly, I couldn't believe how easy it hovered
which may get me in trouble.. The other day I have hovering my 4* about 10' with no problems, so I came around and tried it around -5'.. It was doing good, But was having the "mind" low ground effect, thumbs:-( and she started to fall out towards the belly, I wanted to catch it instead of pulling out so I just gave it a few clicks of throttle, which was to slow and late:-( So it kept falling, I slammed full throttle at about 2', but she kept falling until it hit the wheel of the left side, then it recovered I came around and saw the L.G. bend inward... So I came around and landed she landed fine but leaning that way... But no other damage.... Hope I have as much luck with the UCD.... Idid have a deadstick landing, which I greased in... Have to get use to the 8oz tank, I like flying too long:-))).. It does do all better than the 4* |
RE: U-Can-Do 3d 46?
O.K. guys, i'm back at it. I have been reading on the previous pages about terrible vibration on the saito .100. I own one and have had no problem, but here is my advice. Before first start:
1. Make sure the high-end needle is opened (counter-clockwise five turns). 2. Ensure that low end mixture screw is even with the throttle arm. 3. Make sure that the muffler is tight. after break-in (about 1 and 1/2 gallons): 1. Start engine and open throttle fully. 2. Set high end to peak RPM. ( DO NOT BACK OFF AT THIS TIME)! 3. Attach glow driver 4. Quickly bring engine speed back down to idle. 5. Lean the low end (no more that 1/8 turns at a time) until the engine RPm does not noticeably (as heard by human ear) drop when glow igniter is removed. 6. When no drop in RPM is evident, richen the high-end mixture until the rpm drops about three to four hundred RPM. (I personally drop this much RPM to ensure a plenty (but not overly) rich setting. Drop less at your own risk.) 7. return to idle and get the lowest, most reliable RPM possible. 8. pinch the fuel line to make sure a slight increase in RPM is noticeable. 9. if no increase is heard slightly open the needle valve (in 1/8 turn increments) until one is noticable. 10. run the engine at different throttle settings and see if the vibration has improved. 11. make sure the valves are not overly tight. (just tight enough so that the feeler gauge does not fall out) * a perfect running engine will be impossible to achieve until several gallons are run throgh. This post is just to eliminate the possibility of predetonation. For anyone who has a Saito .90 and a 1.00, the .90 will run smoother because the 1.00 has a longer stroke. THESE ENGINES WILL VIBRATE BECAUSE THEY ARE FOUR-STROKES! they definately will not break the carb off though! (if set as instructed above. My saito 1.00 ran rough until I got several gallons through it and set it as above. (low-end setting is critical.) also, the ticking very slight ticking is characteristic of a saito (unless it's valves are too loose.) if set properly, (valves) there should only be a very, very slight resistance to movement of the feeler gauge. However, I have never seen a Saito that didn't tick when not running. i.e. when being spun by hand. it should not be heard when engine is running. this means your valves are way to tight and being holding down your intake and exaust ports. this will cause damage. it is better to have valves slightly loose than even a tiny bit tight. I have seen engines in which the engine was way too rich which vibrating or too lean and caused vibration due to predetonation. if there is still a lot of vibration, use a cooler plug (O.S. type "F" plug). also make absolutly sure your prop is balanced. Brian P.S. If anyone has questions or comments plese do not hesitate to send me a Private Message and I will do the best I can at answering them. in fact I would appreciate some response E-mail. :-) |
RE: U-Can-Do 3d 46?
CeeGee, Thanks for the link, the videos are great also! Had an exciting time on the last flight, took off and seen something fall off of the air plane! It was black and landed at the end of the runway. My friend thought it was a wheel so he went down to look for it. While he was doing that I brought it back around for a very slow fly by to check it out and it turned out to be the plastic spinner nose cone that came off. So the rest of the day was all starting was done by a chicken stick. I am getting more and more used to the plane each flight. I just have to remember to keep it several mistakes high.
RE: U-Can-Do 3d 46?
Got a question about the UCD with the Mag .91 on it. I just put it on the plane and the wing makes quite a bit of noise when I give it anything past half throttle. It sounds as if the covering is going to vibrate off. Is this normal. I love the way it flies with the Mag .91, just wondering if I'm gonna fly the covering off of it. Had a .46 on it before, WHAT A DIFFERENCE!!!
Thanks for any help you can give. DP |
RE: U-Can-Do 3d 46?
Hey DPRC... I just started flying my used UCD/YS-63 13X4W and have
no vibrations noise??? But it did have a soft mount on it... Not sure what prop your running, but on my 4*60/ Mag 91 4c with the 14X6, I had a lot more vibration and kept breaking off the exhaust pipe during hovering.. I since changed to a 14X4W and have had no problems... Or maybe your covering just need a little heat to insure it's not loose??? |
RE: U-Can-Do 3d 46?
I forgot to put the .91 was on the u can do .46. I'm wondering if that's to much for the wing. I will try heating the wing to see what that does. raideron, have you tried the Ucando .46 with your .91? Just wondering?
But you have no Monocote vibration? Thanks, DP |
RE: U-Can-Do 3d 46?
Vibration noise! I'm dealing with the same issue. I have a new Saito 82 on mine and APC 14x4 W and get that vibration noise in the wings. I put some rubbery type shelf stuff on it where the wings would touch the fuse. I'll find out tonight if it helps. On mine it seems to be the motor vibrating and tranmitting to the wing. (lots of monokote on those wings and it's tight as a drum0
I was thinking about taking some foam rubber like from a mouse pad and fitting it behind the motor mount to see if it would absorb some shock. Any suggestions on that thought |
RE: U-Can-Do 3d 46?
DPRC... No I have not... But I must admit, I was thinking of doing it:-)
Don't get me wrong, the YS has enough power and the UCD is so easy to hover, I guess I was just looking for more pull out power.. Have any of you tried K.E.'s?? Mine couples towards the belly as I guess most do, But it also has some aileron coupling?? Is that normal for this model?? CeeGee... Not sure if that would work, Guess it may help some, but your bolts would still transmit a lot I would think.... I alwys thought about soft mounts for the 4 c's, But brushed it off due to money and weight, But I must admit I like the one on my UCD and think I'm going to use another for my next project with the YS-110.... |
RE: U-Can-Do 3d 46?
how much time have you had on the engines? I'm assuming the engine is set right. Is the prop balanced? just some ideas.
RE: U-Can-Do 3d 46?
1 Attachment(s)
Hey Fun_FLY_3D ... If your talking about my YS63... I'm not really sure..
The member I got it from just said good running but "older" ... I'm still working on tuning.. She does seem to run rich, But not through needle valve settings(I think) but maybe the Reg.... I thought the reg screw just stayed even with the case... But after reading the YS info, I guess maybe not, and was going to mess with it next time at the field.. So do you know which is it??? She runs well, but seems to load up anywhere from fast idle to mid range.. But for my 9 flights, she has stayed running except for two (M.T. tank) deadsticks... I'm not use to the little8oz tk. yet |
RE: U-Can-Do 3d 46?
Hey Raideron, I like your spinner. Looks cool. Well, I got some more time in on the UCD this evening. Man this plane is fun. I'm just getting to know it more now and WOW!! Very FUN!! A guy next to me saw me coming in for a landing and said "hey that's not fair" He was referring to it just floating in. The rubber strips that I put in the edge of the fuse to quite down the vibration seem to help a little but not take it completely away. I would think that what might work is to take a slight amount of the fuse edge off and add some thicker rubber, like mouse pad rubber. That would really isolate the wing. One guy there mentioned that maybe the wire leads to the servos might be vibrating along with the wing. He said to try adding some heat to the monokote area where the wires are and they might stick to the monokote. Might work.
RE: U-Can-Do 3d 46?
1 Attachment(s)
Thanks CeeGee, It's a 2" wide blade trueturn, waiting on the
fillers before I put the cowl on.. And I did not feel safe using just one nut, as my starter would not work when I added the spinner nut as the locknut... Yeah I like the UCD, somethings look a little different because of the long tail moment, But its all good... On the fuse sealers/pad... I've used self adhesive foam tape weatherstrip.. 3/8"wx 1/4"thick and comes in I think 15+' roll from like walmart, Ace or home depot not sure where I do not have any on the UCD but have used them in my 4*60 and Avistar with great success not so much for noise but for sealing the area.. Trying to "stick the servo wires by just heating the surface would be very lucky IMO... I did not want to have two extensions on each servo i.e. one each that stays on the reciever and the other on the servo leads.. So I pulled the servo ends as far out the wing center as I could and used some sticky patch covering to hold in place, which leaves just a short amount left out the wing for my connection, makes it a little harder to connect the servos, but I only use 1ea. servo ext.... and I'm sure there's not much slack in the wings to move around.. |
RE: U-Can-Do 3d 46?
Ok, so your saying the extra "padding" helped some. I've got a great running engine ,Mag .91, with a balanced 15x4 , the coverign is as tight as drum. (I think that's why is sounds so loud)
What is it you are saying about he servo arms? Any other suggestions? DP |
RE: U-Can-Do 3d 46?
Hi people, My UCD does have a little vib. sound at a certain rpm, but
not bad... I may add the weatherstrip, But most likely I'll just fly as is it's no big deal... I did get the YS 63 running like a top.. I finally tached it and with the 13x4 it peaks at 11+... So I guess a 14x4 will be Great:-) the quest goes on to have my sticks move as my mind tells it to:-)) Or maybe I should say what the plane is telling me to do:-) Another tip... don't activate spoilerons during take off, it makes it a little harder to get off the ground.... I guess I accidentally hit the switch as I ran checks before take-off:-(... And to make it worse I wanted to get a long slow run to take-off just to track in the higher winds we had, anyway I had the speed but was keeping it on the ground and plan to lift-off close to the end of the runway, but as I "slowly" pulled on the stick.... Nothing?? I still wanted it to look nice, So I just pulled a little more... Nothing??? finally I gave it a lot of pull as I was just going off the runway's end and off she went:-))))))))) But you know the worse part... I knew the plane was flying different, But I never looked at the switch.... Maybe that's why the plane did not float as much as I thought it would while landing into the higher wind..... As I taxied back I see the ailerons sticking up.. You live and learn they say:-) Over all a Great Day!! DPRC... If I did not miss it I believe CeeGee was talking about the servo wires(maybe) in the wing vibrating up against the covering... and might be causing some of the noise... But it has to be really loose to be doing that??? |
RE: U-Can-Do 3d 46?
HY GUYS,,,,
I´M LOOKING FOR A VIDEO OF U. .46 BUT I ONLY FOUND THE TOWER ONE (9 SECONDS). DO SOMEBODY HAVEONE ?????????????????????????????????????????????????? ?????? THANKS. |
RE: U-Can-Do 3d 46?
:)RCU has written a review on both UCD planes. They both have nice videos. You can get them on this website or you can go to Tower Hobbies and act like you're going to purchase a plane and on the picture you will see the review. On the review pages you will see the link to 4 or 5 videos.
Thanks, Barry |
RE: U-Can-Do 3d 46?
YES TOWER HAVE ONLY ONE UCANDO VIDEO, AND I READ ABOUT 1,5 HOUR THE 2 FORUMS ABOUT UCANDO AND I DONT LOOK VIDEOS [:o][:o][:o][:o].......
SERGIO |
RE: U-Can-Do 3d 46?
ORIGINAL: raideron Hey Fun_FLY_3D ... If your talking about my YS63... I'm not really sure.. The member I got it from just said good running but "older" ... I'm still working on tuning.. She does seem to run rich, But not through needle valve settings(I think) but maybe the Reg.... I thought the reg screw just stayed even with the case... But after reading the YS info, I guess maybe not, and was going to mess with it next time at the field.. So do you know which is it??? She runs well, but seems to load up anywhere from fast idle to mid range.. But for my 9 flights, she has stayed running except for two (M.T. tank) deadsticks... I'm not use to the little8oz tk. yet please check these things and write back and i'll help you as best I can from there. Brian |
RE: U-Can-Do 3d 46?
Thanks for the info fun_fly_3D, I did get it running like a top today,
I just made a few adjustments on the Regulator screw.. all else was set good.. No loading up, Idle down to around 2400, Transitions like a rocket and it tachs at 11+ with the 13X4W... Going to a 14X4W now:-) I love it.... Soon to try the 20/20 for even more eumfff... I might buy the whole case of PowerMaster 20/20 @ $15ea.... Can't beat it... Yeah that's the way the low needle valve on the YS's are, open for a leaner mixture and close for richer.... |
RE: U-Can-Do 3d 46?
More fun flying today with the UCD. What a blast to fly. With my new Futaba 9C set on high rates this plane will do just about anything. Makes me look good at flying. Raideron - When I built this plane I put a Y harness in the same length that is mentioned in the build manual and it is way too long. The ends of the servo wires just stick out of the hole in the wing so a Y harness of only about 6" would work. I had shoved all the extra wires into the wing space so I'm wondering if that could be contributing to the rattle from the wing. My former instructor says it sounds like a snare drum. [:-] Also I'm noticing that the motor is transmitting quite a bit of vibration. I think I'm going to look into some way to isolate it. The vibration keeps breaking the wire going to the remote ignitor plug.[>:]
RE: U-Can-Do 3d 46?
1 Attachment(s)
Thats a lot of shaking CeeGee... are you sure your prop is balanced?
Mine has a slight hum at a certain rpm, but it's not bad, and the soft engine mount seemd to work well... Yeah I'm just using the servo wires and one eack 6" ext.. 2 channels on the ail. and elev. If you are stuffing your wires in the wing, you could wrap them in?? foam and tape it, I'd much rather have them in the fuse.. I stuff the remaining 2/3" towards the tail of the plane on both of my ext.. as such |
RE: U-Can-Do 3d 46?
Thanks for the info Raideron. I think I'll order a prop balancer tomorrow. It's probably better than the way I was doing it. Gotta go............. Rob
RE: U-Can-Do 3d 46?
I just use a thumb balancer, And yes I read most the info about
the non-need to balance our sized props.. It's true APC props come pretty much right on, but had a few that were a little off, and I do at times (very few:-)... "ground trim them" It seems a waste to just trash them, So I make adjustments to my now shorter prop and use painting one prop tip end a little wider if needed... Is this correct???? who knows, But it works for me:-) |
