Prop help please
I am building a plane for a friend and need prop advice. The plane is a ultra stick lite 1.20 engine is a FZ 1.10 ys. What prop would give me the best prefromance . I know he should have gotten the 1.80 Gk.
RE: Prop help please
I would start with a 17x4 APC wide or a wood Zinger 17x5
16x4w APC for 3d or 15x8 APC for a mixed flight, I have also tested a 16x6 Mas, a 17`prop is too much
APC 16x6 is great stuff for general flying ... you should get peak RPM of about 9,750+ on 25% nitro. The 17x5 wood will be interesting. Start with a 16x6 ... was nice when I used it on the Funtana 90 and the Seagull Harrier 90.
ORIGINAL: xxl I am building a plane for a friend and need prop advice. The plane is a ultra stick lite 1.20 engine is a FZ 1.10 ys. What prop would give me the best prefromance . I know he should have gotten the 1.80 Gk. Good luck with your project. And......I don't think you should have gone with the Satio 180. The mighty 110 will work great for this set up if you keep it light. thanks Barry |
