Futaba mixing for multiple servo Ailerons and Elevators
I'm trying to program my 2.4 gig Futaba 6 channel to mix 2 aileron servos and 2 elevator servos on a 3D plane. I can't figure out where to plug into the receiver and how to program the transmitter. Please help guys.</p> |
RE: Futaba mixing for multiple servo Ailerons and Elevators
One servo goes on aileron and one on flaps and turn on FLAPERON...
If using two servos on the elevator, the ONLY place is the elevator spot on the receiver... You will need to use a reversing "Y" or program reverse into the servo.. Myself , I would never use a "Y" on a GAS motor for the elevators... It has been awhile since I have programed a 6 chanel but I think you can program the flaperons with the elevators on a switch to do some wild 3D.. BE CAREFUL cause you can get into flat spins all the way into the ground with the switch ON...:D Walt |
