Picco 26 Max....the DARK SIDE....
How many of y'all have gone over to the "Dark Side, " with that Black and Blue, Ofna Picco 26 Max ????????????????????????????????????????????
I'll start.....I'm there, and I'm already saving for another.....
Tricks I've found that work great, and keep the grin factor at Max level in a REVO....
16/38 gearing
M/S filter on OEM REVO snorkle
Shorten theexhaust header5'16", or the length of the "bell"
Open the muffler outlet to 7/32"
Seal the carb to the crankase with "copper" RTV
HEAT CYCLE your first fuel tank....shut off every time the engine reaches 240-250F, Do NOT idle the 1st tank, run at 1/4 to 1/2 throttle, watch temps, and heat cycle! Do the second tank the same way.....then 3rd-5th normal break-in. These engines are tight and will generate heat, even rich....watch those temps on the first 2 tanks.
During heat cycle, rotate the piston to bdc during cool down, do not restart until temp is beow 110F.
This is what I've found works good....it is NOT gospel, and as another bit of info, I'm at about 250' asl. If you've got a different combo, other observations or ideas on break-in, POST em! But let's keep this thread about the Dark Side, let's complile some working data on the Picco 26 Max HERE.
