RE: help with the clutch
Just a little thing i though you might like cool. I had the same problem with my pull starter...my friend had pulled it out and the spring had gotten bent, so like you i just bent it back into place. But it happened 2 more times...so i looked into new starting mechanisms and i highly recomend the Sullivan Tiger Drive. If you are interested in this your model number, being that you have the 1/10 eldorada, is S680 they cost like 15 bucks just type in Tiger Drive S680 on Ebay if your interested...theres usually a couple being sold.
You would have to buy a starting want to(S686) which is about 10 bucks...but in the end it pays off, no more blisters on your fingers.
You just simply attach the starting wand into a Roto Start Drive or Electric Screw Driver(which is what i use) and stick it in the little hole in the tiger drive and start it up, starts in a second and your hands will thank you.
just thought id say this incase you did want to get a new starter mechanism.
