RE: Servo End Point Adjustment
you want your epa to be around 100. It will function all the way out. The problem is you loose linear control of the servo. If you set your epa to 120 on both sides and slowly move the stick back and forth you'll notice at some point the servo moves faster. kinda like you added expo. this is becuase the signal is not recaluculated across the entire range. At least it does that on mY 6XA and 7CAP
