RE: A question for the PRO'S
hey ehroof i broke down my transmission last night.... one screw holds the clutch onto the gear rods and one tightens or loosens the spring that adjusts the shift time...... hard to explain which is which lol.... the screw that goes deep into the clutch tightens the clutch to the rod..... the shallower hole that you can c half of the screw wall is the adjustment.... or easily you can just back the screw all the way out and if its th e right one you will feel the spring push the screw out and you will know you have the right one!
