need to ship a delta?? My crate
If your are needing ship a delta then you may want to check out this picture of the crate I built for mine. The plane is totally suspended in the crate. There is a metal bracket at the top that the engine is bolted to via the crank. The 4 screws at the top are removed and the plane slides out of the crate. The crate is built out of 1x2 cedar strips. It is very lite but very strong. When the crate was completed it was sheeted with cardboard. Hope this will help others out, BAD ANDY
