RE: need help RE covering PLEASE
I have had SOME luck using my heat gun to bring the oil to the wood's surface, then soaking it with a clean rag. This will have to be done over again as many times as is neccessary, depending on how heavily soaked the wood is. Be careful not to over heat as you may be using it for firewood! I usually use the K2 the last couple of times, then paint with Balsarite. Hope this may help. TeePee
