setxws6,
Speed & dollars are all proportional!! If you buy a meduim range engine, then you will have reasonable speed. If you shell out the money, then you will gert something to blow your socks off !!
Part of the money you pay for a Jett is the aftersales service that is available to you in a posting or a phone call. I have TT's aswell, but if I had a problem with it , how do I talk to the guy that designed it. With my Jett I can get an answer in the same day, all the way across the world from where I am. Where the TT is starting to get a breathless, is where the Jett is really starting to perform.
From what I have read about the West, is if you spend some time setting up the pipe then it will pull really well. I cant see a manufacturer selling a matched pair without it being a well sorted package. When I eventually get a Magnum R then that is the way I am going to go.
Tony.
