Magnum with Nelson, OK?
Edgar,
I whacked a tree with my 1st Magnum (remember to use high rates when you slow it down) and the wing proved to be very strong. It is everything else I would worry about if your engine turns much more than 22k. Linkage must have zero slop, control surface alignment should be dead on, top line servos, reinforce stab, etc, etc..
Mark M.
