RE: First Airplane
further notes on the slow stick mod:
tape the loose wires down so that nothing snags them and they cause less drag. put an extension between the y-harness and the reciever so that you unplug the harness from the extension and dont need to plug and unplug at the reciever. the extension should be long enough to knot around the aluminum stick so if the wing is pulled or knocked aside the extension doesnt pull on the reciever connection.
