RE: Revo Extended Chassis...
i use a 3 racing chassie you can if your running a big block you can use a regular .21 buggy header so the pipe will run on the side of truck and mount the exaust to were the the throttle servo is and you will free up the rear. plus you will get more true performance out of the standard .21 header and every screw in the rear will be easy to get to
