Single Blade Props
I think that, for a high speed plane, the blades don't really go through that much junk from the other blades. I think the main efficiency gain is from the fact that getting rid of the other blades allows you to go to a larger diameter. This assumes that you aren't running into problems with tip speed, which would limit the diameter, but this doesn't usually happen with our planes.
banktoturn
