RE: Reflex 3D All Wood ARF
Before mounting the motor, I soldered a Dean's Ultra connector onto the Jeti ESC and PolyQuest LiPo pack. I decided to use the Kavan [link=http://www.hobby-lobby.com/connectors.htm]HLFK4003[/link] Speed 400 connectors to connect the motor wires to the ESC so that I could reverse the direction, if needed.
The radial mount set for the AXI 2208/34 motor was installed with a small dab of thread locker on each screw. Note that the center of the plywood motor mounts must be drilled out to clear the AXI motor shaft and collar.
I used 5-minute epoxy to mount the side pieces for added strength on the motor mount area.
