RE: Reflex 3D All Wood ARF
The final steps are to mount the ESC and battery. My pack mounted as shown to obtain a balance 95mm back from the leading edge which was in the middle of the recommended 90mm-100mm range.
The Jeti Advance PLUS ESC easily programs by setting the jumpers on the programming card and plugging it into the ESC. I set my throttle to logarithmic, hard timing, brake off, Lithium low-cutoff with slow down.
