RE: NEW 30% BME EDGE II
Received my EDGE-III Everything is in perfect condition!! I have two questions. Should I set the motor distance at 6.75in out from the fire wall to the prop hub or 7in? CG would be my concern. I'm using a Taurus T-52 which is 6oz heaver that a DA-50. 2nd should the CG be in the center of the wing tube?
Thank You.
AL.
I can't believe it came with wing bags for the wings, stabs, and fuselage!!
