RE: How often do you clean your truck?
i clean them at the end of the day. i'll put the compressor at 40 psi and blow off most of the dirt and water, then i hit the electronics with crc hd silicone spray then the compressor again ,then wd40 and the compressor again to remove all the oil and dirt that wd40 took off. its too bad that after its all done it still dosent look new because all the dirt was covering up the scratches,lol.
