RE: Warhead wont run
Just a suggestion because I am far from professional and actually only a beginner at this. I am currently working on a friends Warhead and recently ran into the problem in which it would not run at all. We have come to the conclusion after reseting the enitre carb that the glow plug is losing pressure or not getting hot enough to fire off the engine. I am in the same boat as you when it comes to nothing but problems but have yet to give up on this truck. Hopefully there is some good in it. So give your glow plugs a thorough checking and see if that helps. Good Luck, Lee Alan
