jr10x
Danny, I am setting up my 10x with the flaperon wing setting. the lever on the left of the tx operates the flaps, but they go the wrong way. The travel of the ailerons however is correct. Also when adjusting travel, when either aileron half goes to the down position it travels a lot less than when it goes to the up position. (note that that is the way the flap lever pushes the flaps.) I know the servos travel the same distance when set to a different channel. Could you please shed some light on this as I would like the ailerons to travel equally in both directions and use the flap lever (those levers are awesome.)
Thanks in advance.
