RE: Revo supercharger personal opinions...
For all of you that asked for it here it is:
"Most people overlook the extent to which crankcase pressure and velocity affect small rotary-inducted two strokes. The more you can pack in the crankcase, the more boost it will add to the charge entering the cylinder. The MPPA supercharger increases the incoming air velocity going through the carb and this in turn helps atomize the fuel better in the venturi as it enters the crankcase."
"The MPPA Supercharger disproved the theory that a two-stroke engine couldn't be supercharged. An engine with the supercharger installed on it showed an rpm increase through out the entire power curve."
Displacement: .21ci / 3.5cc
BHP: stock: 2.322 @ 32,851 RPM / Supercharged: 2.598 @ 33,178 RPM
Torque: Stock: 70.416 in.-oz. @ 32,851 RPM / Supercharged: 78.965 in.-oz. @ 33,178
This is from the December 2004 issue of RC Driver.
Look it up for yourself and by the way take a shower to get the egg off your face.
