servos for a 35% extra 26 to 28 lbs.
Dan ...... would the same rule apply as far as not needing a booster when using two aleron servos per wing half. Two will be plugged in to the aleron port and two in aux port. Each y-harness will be 24" to 36" plus 6" extension and servo lead........I fly at the T.O.C. field in Las Vegas if that gives you any more info on the dual conversion receiver question. thanks Chris
