RE: Okay, who's the Kraft radio guru?
any am reciever will work with the kraft am module if you look hard enough you can find a fm module and then you can use current jr or airtronics shift recievers as well as servos.there are kraft narrow band rx out there as well.I have had 3 radios serviced the past year by radio south since aquiring them used and while the cost is more than a new radio I prefer the kraft 7z tx and the mark lll 7cs never had any interference problems with kraft since i started flying in 1971,only crashes i had were either pilot error or batteriers going dead in the flight pack and once in the tx,this was before cycklers were available.
