RE: AEROBIRD EXTREME MODS!
yo Gage
Got the new fuse today £9 ( don`t know what that is in dollars , bout $15 i guess) at least theres no fear with this plane regarding spares, and i can throw it about reasonably roughly without too much worry.
I`ve got to make a start on swapping the guts over , this time however i`m going to incorporate all the mods mentioned previously.
I`ve had a think regarding the horns and have put a pic in the gallery; see what you think?? the horn itself will be a light weight threaded bar drilled at each end , the tension set a little loose so that i`m always tightening to set the trim.
I`ve also seen a large polystyrene glider that will probably take the gubbins from my wrecked "slow stick" for $10.
