RE: Keep stripping spur gears?
gear mesh has got to be WAY off. no possible explanation. loosen whatever adjusts it(motor mount on mine, but I donno on the warhead) and set it so you can run a sheet of paper through the gears. should be as close as it can be without being tight. tiny bit of movement between the gears.
