- You can get a free flight simulator at
http://n.ethz.ch/student/mmoeller/fms/index_e.html You can download a lot of available models into it. Use a two stick analog game controller for $12 from Walmart
The cheapest starter is the Air Hogs Aero Ace. It’s $30 RTF including a transmitter. It’s only controlled by thrust of the two motors so you can’t do loops and it will fly different from a rudder and elevator plane, but its’ tough. It only needs the space of a two car garage to fly.
With a Slow Stick you will go through a ton of props, a motor and maybe a fuselage before you are competent. A Slow Stick does require only the space of a baseball field to fly. It’s more of a “floater”. A Multiplex Easy star is bigger than a slow stick, much tougher, has a very difficult to break pusher propeller and can handle more wind. It's available RTF for about $180 and as a ARF for $55. The Easy star requires the space of a soccer field to fly. They soar well. See
http://www.plawner.net/3/1st_plane/ in which he recommends mainly Multiplex planes for their toughness and ease of construction. They also fly very well. Other options from Multiplex are the Easy Glider and the Twin Star II.
- I think the best idea would be to get a receiver ready Mutliplex Easy Glider Electric, which is all built except the receiver installation and get a JR Spectrum radio and receiver for it. Would make a 4 channel great trainer.
http://www.redrockethobbies.com/Spe...M_p/spm2460.htm
http://www.hobbypeople.net/gallery/240107.asp
- A wise addition to most planes:
http://www.aeromicro.com/Catalog/gw...ba__1500029.htm
