RE: Four Star 60
Nope. SIG wisely recommends moving the engine as far back as possible on the mount. I did this plus put the servo tray way back. CG check showed it slightly tail heavy, but it flies great. Bottom line; Put everything as far back as you can. There is such a generous wing loading that if you don't you'll end up with a nose heavy airplane.
