McCulloch 32cc on a 85" 14.5lb Extra 330?
it's a KMP model I got for free that needs a bit of work and all hardware and stuff, and I have a McCulloch 32cc sitting around, here's the specs on the plane that I know (about all I know about it)
Weight :16.6 lbs
Fuselage length 78.5 inches
Wing Span 85 inches
Area 1424 sq. inches
Engine 3W-50cc, G-62, MVVS 58cc
the engines it lists are supposed to do 3D, which I'm not worried about as I just solo'd not too long ago... I've seen that the McCulloch's are supposed to be torqy and there's a bit out there on moding them, but I figured I'd ask those with more experience than those I know, but we're also planning on putting a Ryobi 31cc on a 60 something inch Cap 232... man that was a fairly simple conversion
btw, do the 28 and 32 have the same cranks? I have two 28's and the 32, if a 28 would fly the thing I'd almost rather use one of them, the 32 is on a nicer trimmer... but if the parts could be put on a 28 and be the same, that would work too. if this doesn't work, I'll keep looking for something in the 40's I guess...
Thoughts? opinions?
Thanks! getting excited...
