RCU Forums - View Single Post - K&B .40 DELTA
Old 05-31-2006, 09:05 PM
combatpigg
combatpigg's Avatar
Default K&B .40 DELTA
It is about time to build a plane for this engine. The speed plane project is on hold until I get the fuel system sorted out. That plane needs to have a Tetra tank retrofitted, I couldn't get the bladder system to work. I figure this delta will be easier to get a working fuel system with, then I'll transfer what is learned here into the speed plane. This delta has 31" of span and will probably weigh 2.5 pounds by the time it is done.
ID:	469637   Click image for larger version
