RE: GWS Pico TIGER MOTH - Flight Report
Say Guys:
A couple of the can motor Gurus at RCG (vintage 1 & Dean of Milwalkee) have found that if you use a 3s lipo with the little IPSA motor you can get about 20% more power. You have to use a 7X6 or 8X4 propwith the A gears to keep the Amps at 2. The increase in voltage really make them sing with-out any heat build up if you use the GWS heat sink. Motor life is much the same as normal
Bob
