DD with OS 25RE/pipe.
as for it rolling out when doing loops you may want to check to make sure you have even throw. Check to see if both elvons are even at max throws up and down. Also check if they stay even as you gradually advance throws on the elvons.
They should be equal the entire time of travel.
