ORIGINAL: Custamizer
only 1 cm bigger though so it won't change it much the rear axle will be .5 cm higher off the ground
Since the pinion / spur can not be changed (only the stock combination) so the only way to change gearing is through the tire.. if I want to put some brushless on it, that's the wrong way to go!! Oh well.. maybe put a cooling fan on the motor and hope that it won't get too hot!
Or just stick with stock brushed motor... !!
