1
Wayne
Using one Matchbox.
Have 4 aileron servos, one in each wing, each going into the four slots into the Matchbox. One extension going to aileron slot in RX. Did not use the jumper cable, used separate battery, just for box.
You might of been able to have done the same with yours, but I thought you had a neat setup with them in your wing as you did. Would have to figure out wiring (probably like mine is setup).
Do you go from box to aileron slot on one side and to box to aux on the other?
Next time we fly together we can take a closer look at both setups.
Using Hitec 545's non digital all around except Hitec digtal on rudder.
Roger
