JR10X & Hitec fm recievers (shift selectable)
The 10X is capable of SPCM, ZPCM, and PPM. If your hitec receivers are made for JR, or are positive shift, they will work. If they are made to work with hitec or futaba they will not work with JR. The servos should work fine. There are some shift selectible receivers out there, if you have them, they will work also, just put them on positive shift. I hope this helps!
