If you wanted to use it on the 50 MHz band, you would use a 50 MHz crystal. You must be a licensed radio amateur to use the 50 MHz band.
- Jeff
A receiver designed and tuned for the 72mhz band cannot be operated on the 50mhz Amateur Bands. It would not function with a simple crystal change.
Gary
