spacers
Chuck we had to make urethane spacers to put under the engine to elevate it, the carb sits a bit too low on the standard mount.
If you need a set, let me know, we'll send you a pair.
On the Extreme we dropped the tank by almost a 1/4" to accomodate the rear pipes without having to alter the mount or the header, most all pipes clear the tank on the Extreme with no problems..
