Originally posted by Rudeboy
That F5D airframe is not designed to take I/C engine vibrations. Come to think of it, it probably isn't designed to hold up with that kind of power either.
If you wan't to go that way, I'd take an F3D airframe fitted with a hot rear exhaust engine (Jett Fire 60 or some .45 DF engine)... Would be an expensive plane though.
I meant an airframe with the shape of an F5D but with a stronger construction.
A F3D airframe has to have all sorts of minimum sizes which doesn't help drag reduction.
I thought a MB40 or Nelson FAI was a lot hotter than the engines you mentioned?
Greetings and happy holidays,
Paul
